Getting an error to replace the cartridge, so i did, but the error message wont clear, or accept the new cartridge.
SOURCE: need manual for a epson picturemate deluxe 500
Hi-
If you want the USERGUIDES and MANUALS for this printer, click HERE
Thanks for using Fixya!
SOURCE: EPSON PictureMate will not recognise printer cartidge.
This happened to me. I could not get any help. So I swabed the contacts w/alcohol and success!! Mind you, my Picture Mate is over 2 years old, I would not try this w/a printer under warranty unless directed by Epson.
Good Luck
SOURCE: Epson PictureMate personal photo lab
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: All my picture from my
Hi!
You need to run a Head Cleaning cycle so printer can get rid of the old ink from your previous cartridge. Try running it from maintenance for at least twice or try printing pictures in between cleaning cycles.
Hope this helps.
SOURCE: replaced ink cartridges in epson
general error normally comes if the printer carriage movement is obstructed
try doing the following
1 switch off the printer and switch on after some time and see that the head carriage moves properly or not if not than
2 look for obstruction in the carriage path
3 the cartiages installed might not be seated properly try reinstalling them
