The Fridge is connected to an outside tap,with a copper water line which goes in to the back of the refrigerator,no filter to be seen,i have looked in side of doors no filter,and under front grill .still unable to locate filter it must have one.
SOURCE: Amana refrigerator water dispenser not working
No you don't. You have two water solenoids in the back. One for ice, one for water. Pull line off water solenoid and blow into it. For more help go live chat.
SOURCE: Amana af12538aes Refigerator No lights, ice, water
There's no ice
If your ice maker has stopped producing ice completely, check these, in this order:
Small or too few ice cubes
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
Specks in the cubes
If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
SOURCE: Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
SOURCE: Water dispenser not working
I have a Hitachi R-M800GM.
When i operate the water dispenser, water flows out from the dispenser [not strong flow]. There is also water flowing out at the bottom of the freezer door [hinge area]
I think the line running inside the freezer door may have come loose? If so, how to reattach it? Do u have any layout drawings of how the hose is being connected.
Please help.
Thanks,
Rick
