Question about JVC HD-52Z575 52" Rear Projection HDTV-Ready Television
HDMI interface issues
I have a JVC HD-70G886 being fed an HDMI signal from a DIRECTV H20 unit. All was well until a power outage. When everything was turned back on the picture looked like it was trying to search between formats (480,720,1080). HDMI reset performed on the JVC (was showin NG9) all ok after reset. Still showing same symptoms. Reset DIRETV box no change. replaced DIRECTV box with other H20 from other room (connected to MAXENT plasma and working) still same problem. THis has happened before and was cleared with JVC reset and DIRECTV reset. But will not clear now. Any Ideas?
  • 43 Answers
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Posted on Aug 02, 2009
6ya staff
SOURCE:
My ps3 wont hook up trough hdmi
You may have a fault in the HDMI cable. Swap it out first.
Jun 14, 2014 | JVC HD-70G886 70" Rear Projection HDTV
JVC SP55M HDMI sound quit after power outage
Unplug unit, wait 10 mins then plug back in. If still does not work, check for breaker trip. Be sure outlet still has power.
Nov 27, 2013 | JVC Audio Players & Recorders
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
I get flashing green on my screen when the hdmi cable is hooked up. This only happens after a power outage. How do I reset it?
usually you need to plug the HDMI connection back in, and power everything up. Then using the menu, set the HDMI connection, back, to whatever you wish, often it is efficacious, to have the alternate unit already plugged into the set. It may also pay to reset your TV set, back to defaults.
May 19, 2010 | JVC HD-52G786 52" Rear Projection HDTV
42" 1080p Flat-Panel LCD HDTV: no signal after power outage and have tried resett...
Try hooking something else up like a playstation or dvd see if it works so you know if its the box or the tv
May 16, 2010 | Insignia 42" LCD Flat-Panel HDTV
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
H20 Reciver power up problems
same problem on two different h20 receivers - called directv and explained the situation each time. since these are leased receivers, new ones on the way.
Apr 19, 2008 | Philips DIRECTV H20 DTV Receiver
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
371 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
