It is a delta 12 inch planer ,model number 22-540 type 2
You are looking at a major disassembly to get at the cutter head bearings, everything is built around the cutter head. The motor drives the cutter head on one end of it and the cutter head drives the rollers at the other end. Most of the components have to be removed to get the cutter head and it's bearings out. You can go to www.ereplacementparts.com and do a search on your model number for a good breakdown of your planner and see what you need to remove to get at the cutter head and it's bearings.
SOURCE: how to change planer blades
you will need the directions from the owners manual , do not guess at this it can be a hazard if not done properly i have manual and will try to look it up and figure how to get the info to you
SOURCE: Need an user/owner manual for a Delta Shopmaster
Heres your Manual:
http://powertool.manualsonline.com/manuals/mfg/delta/tp300.html
I used Ned Whites' addvice and ordered a new one .Just by looking at it , it would be a very involved job.Parts and labor would more than a new one.
