Cleaned air filter and changes plug but still runs rough and uses about twice the gas that it has in the past. It is between 2 and 3 yrs. old. It is washed down after every lawn mowing.
SOURCE: Briggs & Stratton Quattro lawn mower
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
SOURCE: Mower stutters when i turn up to full throttle.
Hi if it is older than 2 years it will need a new diaphram and gasket under carby you will also need to clean out the fuel bowl in the top of the tank this should fix your problem.
SOURCE: Having trouble with Mower...what to do?
Clean out the carburetor float bowl and main jet. Sounds like dirt or moisture in it
SOURCE: how do i tighten the clutch for a Model 28b702
how do i replace cluths on snapper riding mower
SOURCE: I have a briggs and
A champion cj 8 plug will work fine. As far as air filter it is probably a paper on, take the old one to a dealer or small engine repair shop and they can match it up for ya.
