Where excatly are they at?
SOURCE: toyota 1998 sienna foot break light indicator on
The brake fluid level in your master cuylinder reservoir is low.
SOURCE: 2004 Toyota Sienna LE sliding door failed after battery jumpstart
could very well be the relay for the power door and possibly the interior light relay... they are located in the fuse panel under the dash.
Robert
SOURCE: The sliding door handles of my 1998 Toyota Sienna have both broken.
I replaced both of my sliding door handles this weekend. It was actually pretty easy. Cheapest I could find the handles was a little over $70 each. The interior panel is held on with one screw and 10 nylon clips. The one screw is in the cup holder. Put you hand in the cup holder and push out at the bottom. It pops right off exposing the one screw. I started on the clips from the top at a corner. Seemed to be the easiest place to slide a screw driver under. Once I got the screw driver in, I started working my fingers under the panel. The clips run mostly along the top and bottom about 6 inches from the edge. I made an effort to apply the force as close to the clips as I could to reduce flexing the panel. Once I got the first clip to pop out the other followed pretty easy and the panel lifted right off. Carefully peel back the plastic barrier. The exterior handle is held on with two 10mm bolts. Connecting the short cable was pretty obvious once you could see everything. Now I have to teach everyone to open the side doors very gently! Hope this helps.
SOURCE: toyota sienna interior lights not working
The problem is in the sunvisor light. You will have to take the light assembly off and you will find wires have become disconnected.
Daviscacare.com
757-689-4701
