Question about Proform Exercise & Fitness
My treadmill won't run, but turns on
My treadmill turns on, the screen lights up, but when I put a speed into it, nothing happens. The screen shows the correct speed but the motor won't run. This has been happening since we moved to a new house. The treadmill is a proform cross trainer.
  • 3,904 Answers
It sounds to me like during its move the drive belt came off off the motor that connects the motor to the walking surface. If the motor is not running at all after checking that I would look for a reset on the motor itself and check all connections. Not likely that the motor is fried but that would be the last in line for checking.
Posted on Aug 31, 2012
6ya staff
SOURCE:
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Proform 560 crosstrainer treadmill powers on belt won't turn
LUBE THE deck belt+ rollers bearing too. God bless you
proceed according with the video attached.
Jan 07, 2013 | Proform Exercise & Fitness
Sole treadmill says "INITIAL" on the screen and won't run. This occurred after I removed the magnetic emergency stop switch.
Normally you must put the key in the hole, after you press the button start and ready.
However I recommend you to follow the instr. manual for easy start. Since that every manufacturer has a little diferrent mode of start. If you do not have it download free from
www.fitness.manualsonline.com
God bless you
Dec 17, 2012 | RTO Sole Fitness Package F85 Treadmill &...
My Sole f83 will not start. initially Fans run, can raise/lower. will act noemal until motor should run/doesn't. then raise/lower function stops. If I try to use speed buttons LS light shows. moto
LUBE or wax the deck belt, this happen because you do not have schedule maintenance according with the owner manual. The machine shut down for autoprotection in electronic system Do it NOW.
2) LUBe the rollers bearint too with WD-40 only for rollers
3) Test the drive belt motor, for worn or cracking belt, replace or adjust it
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubelshooting help.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 15, 2012 | NRS Sole F83 Treadmill
Cybex lcx 425t won't turn on
Check under the front hood shroud and look for breaker reset on motor controller. Also check to make sure it is all plugged in in all connections of the power supply as they are known to shake loose after some time.
Oct 05, 2012 | Cybex LCX/425T Treadmill Refurbished
Perform maintenance light on but holding up buttons for speed and incline don't work
Dear Sir:
1) Tight very well the flexible cables from key pad + connectors.
2) Tigh the connector from speed sensor , clean the speed sensor, and adjust it see the diagram attached.
3) Tigh the connector from incline or elevation motor very.
4) Tight every wires inside very well,for loose wires.
5) After if every thing is o.k now, Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP. sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Apr 07, 2012 | Exercise & Fitness
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
Exercise & Fitness Logo
1,761 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Android Man
Android Man
jay kaye
jay kaye
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
