SOURCE: configuraton of my computer for aSmartdisk Fdusb-tm2
You need to find and download drivers for the drive, this usually isn't the case though if you are using an up to date opertaing system.. serach online for "Smartdisk FBUSB- TM2 Drivers" and this should sort out the problem after you install them and re-start the laptop..
SOURCE: SmartDisk:FDUSB-TM2
Good indication that it probably isn't compatible with Vista. The only thing you can do is either return the floppy drive for refund, or downgrade vista to XP so you can use it.
SOURCE: Can't load SmartDisk FDUSB=TM2 on Vista Premium 64
Windows Vista carries a lot of glitches ....we need to give it more time as it improves. The XP environment works better with older technologies like the smart disk floppy drive. My advice is for you to partition your hard disk and place Windows XP on one side and still keep the Vista on the other. That way you can have both OSystems and still be able to use your floppy drive. Alternatively you can upgrade and use a flash drive storage or DVD/CD. They are newer technology which are more compatible with Vista.
Cheers & Kind Regards
SOURCE: I need drivers for a FDUSB-TM2 external floppy
go to folowing link for your drivers
http://www.opendrivers.com/company/2660/smartdisk-free-driver-download.html
SOURCE: where can i buy new floppy disk drive smart disk
smarty disc are not so common now as we have hdd and key back ups i would try lookijng on ebay not the best addvice im sure but just trying to help
