SOURCE: tv shuts off after 10-20 minutes
its not the problem with ur electron gun tube or with any picture ic or sound ic. Every t.v. is microcontoller switched machine.
any damage to microcontroller ic that controls the switching will lead to this kind of problem.
0.01% chance of residue EHT voltage would have affected the microcontroller.
SOURCE: LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
SOURCE: turn tv off for a
Hello. Panasonic 10 blinks issue have special troubleshooting flowchart to diagnose problem and could take some time for professional like me to correctly figure out faulty board/s. You can start with power supply board replacement just because out of my experience it is bad about 80% of the time. And most of the time another board is affected as well.
I would not recommend homeowner to try this repair without appropriate skills, I know several cases when professionals wasn't able to diagnose problem properly and ended up losing too much money and effort.
In case if you have two boards in bad shape - you already looking to spend not less than $400+ in parts.
Maybe better way is just to invest in new one. And stay away from plasma technology. It is a science project that never got finished.
I would recommend LCD or LED Panel TV.
Regards.
Russ.
SOURCE: after 1 hour or so
The power supply board is not yet dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem......
Programming the Sleep Timer:
