I have a Bosch Classixx 1200 Express and it goes through the normal washing cycle but when it gets to the SPIN cycle it just stops. I have tried putting in on this cycle manually but still nothing.
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
i have a bosch 1200 clasixx there is a noise coming from the drain pump.i have manually unblocked the filter but have notice the the fin is not turning while it is trying to drain when giving a little spin it will work fine.it will not spin also.i have order a new pump.am i on the right road
i have a bosch 1200 clasixx there is a noise coming from the drain pump.i have manually unblocked the filter but have notice the the fin is not turning while it is trying to drain when giving a little push.it will not spin also.i have order a new drain pump am i on the road
Will not wash above 40o
