Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC I ART
I have a JVC rear projection that has red wavey line on the top and bottom of the screen but the mittle looks ok. Any ideals? Thanks Robert
  • ROBERT THRASH Apr 12, 2007
    Can you help me with were they are in the tv. I have some tv skills be it has been awhile. I have been repairing IBM check sorters for 20 years but need some info of where these are in the tv. Thanks Robert
    President:
  • 1,284 Answers
You need to replace the convergence IC's. That is the most common issue with any CRT type projection TV.
Posted on Apr 07, 2007
  • Duke
    Duke Apr 13, 2007
    If you take off the front lower grill (4 screws 2 on each side and 2 more small screws behind the input door on front) then remove the panel which if I remember has 4 to 6 screws holding it. You will then see the convergence board with 2 STK392-110's or some variation of them on the convergence amplifier panel. You will have to check the associated resistors around the IC's as most likely some might be bad. If you replace one IC's you need to repalce both of them.
Anonymous
SOURCE:
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
I SEE DOUBLE THE PICTURE AT THE TOP LEFT IS WAVEY
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 28, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Phillips 60" projection screen tv. Wavey lines at top and bottom of screen center is very blury and wavey almost looks like 3d. Audio is fine. How do i fix this
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
Jul 19, 2010 | Philips 60P8341 60" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Wavey line and double image
Your TV most likely has a problem in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 19, 2009 | Mitsubishi WT-46809 46" Rear Projection...
JVC AV-56WP74 56 in. Rear projection blurred image
Check that the 3 output plugs are in the right sockets (Red, Blue, Green) There is usually a felt pen colored mark on a white tape on the plug in wires. The Board sockets are marked Red, Green, Blue.
Easyab
Jun 20, 2008 | JVC AV-56WP74 56" Rear Projection...
Double and bouncing lines
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 12, 2008 | JVC AV-48WP74 48" Rear Projection...
Red lines on screen
REPLACE THE CONVERGANCE IC"S.STK392
Dec 23, 2007 | JVC AV-48WP30 48" Rear Projection...
Bowing red lines at top and bottom of screen
Try this, it might be just the thing:http://www.techlore.com/article/15929/Fixing-My-Own-TV/?textpage=3
Sep 19, 2007 | JVC AV-48WP30 48" Rear Projection...
Converge problem
Sounds like convergence issue--replace Stk IC's mounted
on large heat sinks. Check power supply for open fuse device.
Re-check convergence alignment.
Aug 11, 2007 | Philips 60PP9352 60" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
195 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
