Philips 47PFL7422D/37 Television Logo
Donald Free Posted on Aug 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Phillips Model 47FL7422D/37 must be turned on several times before the picture comes on. What is the problem?
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Aug 29, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292381
Points
3377
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
5 Related Answers
Anonymous
  • Posted on May 28, 2008
SOURCE: Black Screen after 5 mins. of use
It sounds like the entire screen goes blank with your problem. My problem is the lower half of the screen goes blank. Do you think the SSB is also the problem? What are your thoughts about the "Video Board" or the X Board?
Do you know where to purchase parts?
tlm931
T.l. Moore
  • 273 Answers
  • Posted on Oct 24, 2009
SOURCE: i have a phillips 50 inch plasma- model
you have a problem on one of the boards in this unit you would have to start isolating the source to pit it down
its probably best you get some help form a servicer in your area this is a philips inside and made by samsung
yeroc
Custom Exchange
  • 397 Answers
  • Posted on Nov 30, 2009
SOURCE: I purchased a brand new plasma model 42 pf9630A/37
probaly your y-sustain board
Anonymous
  • 1779 Answers
  • Posted on Dec 11, 2009
SOURCE: phillips tv model #42pf5321d/37 we replace the
You should have downloaded the eprom information onto a usb stick then transfered it back to the new board, or just removed the eprom off the old board onto the new. It is my recommendation to have an authorized service center come out and realign it within the factory service mode.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Apr 01, 2010
SOURCE: PHILLIPS PLASMA TV MODEL #42PF9431D/37 Heard
Hi, Usually any "Pops" are an Electrolytic Capacitor "blowing up" quite literally, or "Gassing" as it is called. This happens due to some sort of power problem. Capacitors hate AC Voltage and Current, and Heat and Over Voltage. All of which, I have no doubt it was exposed to before it went "Pop" This is only a symptom of a far greater problem, to come, no doubt, soon, the rest of the set will fail too. Please DO NOT USE. this set any more, you risk fire or explosion or both. If you MUST use it at least unplug at bed time. Theses days home repair except for the most rudimentary problem is not feasible, setting aside the safety aspect. In my professional opinion, I would recommend, that you get a "Quote" for repair from a Philips Authorised Service Agent This is very important, that you contact a Philips head office and ask for a referral. This way at least you can make a decision to repair or replace.
I have a Philips Model 47FL7422D/37 the left side of the screen is darker than the right side and I can not adjust it. What is the problem.
Scrren problems can be a bad screen or a bad t-con board. The only way to check wich one is by trading out the T-con board, If the problem goes away it was the T-con board if it does not it's your screen. To find the part you have to get the part number from the actual part. you can order parts for this TV at www.interliquidparts.com
My phillips model #32PFL5332D/37 flat screen will not come on
You have been the victim of a power surge. It will need to be repaired in order to work.
2helpful
Phillips hdtv model 30pw9110d/37 won't turn on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
No picture or sound just six red blinking lights
Use your warranty in a hurry before it expires. Your TV when into protection mode to prevent further damage. Most TVs have a 1 year warranty. Good Luck.
Have a PET726/37 and the "slave" will not show a picture, have sound but no picture on the "slave"
my phillips portable dvd player, model pet726/37 has sound but no picture. What can I do to fix it?
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
3answers
NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
check the wires inside at the left lower region as you are looking at the rear. There are several circuit boards there that tend to loosen when moved. The cables are really ribbons like those used in computers.  I'd lioke to be more specific however I'm not entirely familiar with this model, just rear projection tvs in general.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
