My Samsung N-120 netbook suddenly stopped connecting to internet. I watch videos at night and then turn it off. When I turned it on today, all of a sudden IE8 won't connect to internet. I've checked and wireless is connected with excellent strength.
Are you using a router? Do you use cable internet? Try connecting directly the cable directly into your netbook. If you have internet access then the issue may be with your router.
Admittedly, I haven't tried that, but other laptops connected via router are able to get internet. Should I still try it? Could it be my wireless connection settings on the netbook???
Yes that is possible. If this recently happened, did you try a system restore to a date where it was still operating correctly?
SOURCE: internet connection is present but internet explorer doesn't find
Hi there
Go to the modem and remove the power supply for around 30 secs, then plug it back in and leave it a minute to reset, if you still can't connect post back
Good luck and thanks for using Fixya!!
SOURCE: internet connection?
Try and ping something. From the dos command prompt type: ping www.google.com
do you get a response?
SOURCE: Internet Explorer 8 fails to connect
Run the following command. It should help
Click on start > run and type in the below mentioned commands one by one.
regsvr32 urlmon.dll
regsvr32 hlink.dll
regsvr32 msjava.dll
regsvr32 mshtml.dll
regsvr32 jscript.dll
regsvr32 vbscript.dll
regsvr32 shdocvw.dll
regsvr32 browseui.dll
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 dssenh.dll
regsvr32 cryptdlg.dll
regsvr32 gpkcsp.dll
regsvr32 wucltui.dll
regsvr32 wups.dll
regsvr32 initpki.dll
SOURCE: slow internet at 120 Kbps but fast connection at 54 Mbps Why
54 Mbps is the speed between your computer and your wireless router. The .8 Mbps is the speed of your connection between the router and the internet. You should call your ISP and ask what your speeds should be; there could be something wrong on their end or your modem might be malfunctioning. It's also possible that your WiFi connection itself has a weak signal. That can be corrected by moving the router and the computer closer together, or getting a signal relay and putting it between them.
