Question about GE GSS20IEP Side by Side Refrigerator
Water leaking out of freezer door water dispenser
I have the GE Side by Side model # GSS20IEPH WW and it is leaking water out of the water dispenser in the freezer door. I have shut off the water and the leak has stopped but if you turn the water back on it starts to leak again. It does not leak very fast but it is steady drip. The ice maker works with no problem.
  • 6 more comments
  • Anonymous Apr 06, 2007
    Where can I find an exploded view of the refrigerator so that I can find those parts?
  • J Kli Jul 21, 2012
    We are having the same problem! And we cant figure out how to atke apart the dispenser to fix it. Did you resolve this problem?
  • Anonymous Mar 14, 2014
    leaks beneath freezer side by side
  • Anonymous Mar 16, 2014
    Water leaking slowly around Dispenser
    door
  • Anonymous Mar 20, 2014
    water leaking by ice and water dispenser
  • Anonymous Mar 21, 2014
    is there a valve in door
  • Anonymous Mar 26, 2014
    Leaking out back when ice maker cycles on also no ice
  • Anonymous Mar 30, 2014
    Water dispenser tube leaking on back near floor when water is dispensed
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Posted on Apr 04, 2007
6ya staff
SOURCE:
How do you get the water dispenser on a GE side by side model GSS201EPD WW to work?
Chances are that the=> WR57X10050 Water Inlet Valve has become defective on the dispenser side of the valve.. I am here should you have questions, Thanks John T. Appliance 911
Jun 28, 2015 | GE Refrigerators
How do you fix the water dispenser on a GE side by side refrigerator model GSS201EPD WW
Here are a couple of possible problems. Most common one is a defective water inlet valve. It is the plastic assembly at the lower back area where the house water connects to. On dispenser systems it is actually 2 valves in one unit---half lets water in to icemaker---the other half lets water dispense at door. It is electrically operated so if half goes bad , the other half can still work. If bad it needs replaced as a complete unit.
Second possible problem with some GE side by side models is they had problems with the water line in the door going to the dispenser sometime would freeze up. They came out with a heater kit that needs installed in the dispenser area to defrost the water line. Call GE service with your model number and they may be able to tell you if you need that kit installed.
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
Water dispenser will come on at random times
are you talking about the lever where you put your glass to get water or the ice compartment if it where you put your glass to get water it could be that if the pressure is not strong enough to close the valve after you have taken a glass of water or a defective solenoid vavle thanks from gilles
Jan 17, 2009 | GE GSS20IEP Side by Side Refrigerator
GE Freezer Side Ice Dispenser
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Jun 16, 2008 | Refrigerators
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
1,724 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
Vish Iyer
Vish Iyer
