The water heater is an A.O.Smith, not in your list. Model FGR 40 242 cap US. It is leaking at the top around the hot water outlet. Can this be fixed, or is it time for a new heater? Part No. FGR--40-F00N01010R99 SN GA01-6197095_R99
You have to replace water heater.
But you can buy-time if leak is small by turning heater off except when you need hot water. This will give you 30-60 days to shop and find best heater.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
To prevent tank from rusting in this manner, inspect and replace anode rod each 2-4 years, and keep water pressure below 80psi.
http://waterheatertimer.org/How-to-maintain-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Hot water tank leak
drain valve must have already been leaking, that's why someone put the cap on. It's ok to cap the drain but never the pressure/temp relief. If the water is coming out of the drain (not around it) you could either replace the cap or the drain valve to stop the leak - otherwise it's time for a new water heater.
SOURCE: GE Profile Smart Water Heater leaking at top/no hot water
Hi, has your problem been solve yet? please respond
Thanks
SOURCE: water heater leaks on top
As joe explained tape or pipe dope would be recomended also there should be a seal inside the ends of the short pipe. make sure that seal is seating squarely on the pipe as to make the proper seal it may behoove you to actually take it back loose and visually inspect the rubber seal inside the nut to make sure it is not damaged or defective.
SOURCE: water is leaking UP from hot water outlet on to
you guys are crooks. Take me off your e-mail list
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
