Cable provider tried to troubleshoot, without success. Told me to contact Olevia directly to get help walking through steps to get cable signal.
SOURCE: QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
SOURCE: HDMI is not working
Some Hdmi signals are not working with some tvs at this time. It is a fighting battle that tv techs are dealing withe everyday. At this point the tv manufactutre will tell us what I am about to tell you. Hook up the composite and wait for a firmware upgrade to fix this. A perfect way to see this is a problem between cable box and tv and not just your tv is to plug in a dvd player with hdmi out if it works firmware will need to be developed if not your tv needs to be exchanged or a new main board.
Josh
SOURCE: No cable signal on 32" flat panel Olevia tv
When you write 'tuner,' do you mean the internal TV tuner or do you have a cable box between the wall connector and your set's input?
If you are connected from the wall to the set, then the sensitive circuitry (it may only tolerate a few volts max video) is damaged.
If your set was a couple of decades old, it might be fairly easy to repair.
If the set was damaged via the cable service, you may have some recourse unless your cable provider has seen fit to absolve themselves from liability, I suspect they have.
I do not know your set but it is not impossible that the video input circuitry for cable and antenna is on a smaller assembly that processes it before reaching the main board.
The latter has obviously survived since you still have the other functions.
SOURCE: says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
SOURCE: my olevia tv is not sensing the hdmi input right away.
HDMI has to be able to communicate with each other. In most cases the HDMI issue is with the device connected to the TV and not the TV itself. If you did firmware upgraded on the TV then the issue is with the laptop. Try the laptop on anther brand of TV and see what happens.
