Question about Acer Aspire One PC Notebook
Hang on entering bios on acer aspire 4752 how to solve this problem?Plz help me
  • Hayat Khan
    Hayat Khan Oct 25, 2018
    may be there is some problem in keyboard check the keyboard remove the cable of keyboard then check
  • Anonymous Oct 26, 2018
    6 year late? did they stare at it for 6 years
    and wonder why the HDD died, ? or XP got infected?
    Master:
  • Acer Master
  • 459 Answers
1) When the bootup is in progress, reboot your Personal Computer. The list of keys that must be tapped appears on the window.
2) The Del or F2 buttons should be pressed, this varies based upon the model of your Acer computer.
3) Press and hold the Ctrl, Alt, and Esc keys on your keyboard to open the set of instructions that controls the input and output functions.
Posted on Dec 29, 2018
  • Acer Master
  • 27,725 Answers
Restart your computer during the boot up process you will see which certain key/s to press to enter set up for a very short time usually the Delete or the F2 key
this will vary depending on your computer
Turn on your Acer Aspire.
Press and hold the "Ctrl" key.
Press and hold the "Alt" key.
Press and hold the "Esc" key.
This key combination will open the BIOS on your Acer Aspire.
hope this helps
Posted on Aug 22, 2012
  • 4 more comments
  • Sujit Thapa Aug 23, 2012
    thanq but not working. it is hang on startup when acer logo display. Any other suggestion...! plz
  • Brian Sullivan
    Brian Sullivan Aug 23, 2012
    restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse select the safe mode option and try the system restore To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK 2.On the General tab, click Launch System Restore 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information 5.Select a system checkpoint or an installation restore point, and then click Next 6.Close all other programs 7.To start the system restore, click Next 8.Your computer restarts Repeat steps 1 through 8 until you fix your configuration issue
  • viralPh Video
    viralPh Video Oct 04, 2018
    Brian Sullivan your sugestion is useless because the problem is in bios corrupted not the operating system try to read the probleam before commenting
  • Anonymous Nov 01, 2018
    8 years old, 2010 made.
    all batteries no good ! both!
    now HDD bad.
    gee the hanging is normal when BIOS can not find a working boot medium, all PCs do that like that.
    some smarter even have A Post code, HDD is dead)
    we test the HDD next in EVERY CASE this old.
    page 49 (pdf 69)in your manual covers D2D recovery
    disk to disk recovery.
    and works only with acer media. (hint hint)
    alt + F10 starts this process.
    but you will need help from Acer.com
    guess what fixya is NOT ACER.Com
    all we can do is point and read the manual to you or tell you how to test any PC.
    now your manual, https://www.acer.com/ac/en/US/content/su...
  • Anonymous Nov 02, 2018
    Hayat Khan Oct 25, 2018 , 6 years late.
    I say dust bin these posts.
3 Suggested Answers
6ya staff
SOURCE:
parrotheadpc
Chip
  • 2600 Answers
SOURCE: Reset Bios Password for Acer Aspire 7720Z Notebook - Ron M.
Here is the link to your service manual, when you click on it and bring it up...it is a pdf file so you'll need adobe or another pdf reader, go to page 40, that is the directions for resetting and removing the BIOS/hard drive password. Good luck
http://tim.id.au/laptops/acer/aspire%207730%207730g.pdf
Posted on Sep 27, 2009
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: acer aspire one 1640Z XP BIOS RECOVERY WON'T READ USB WITH BIOS
if I understood correctly you have the recovery software loaded on a stick flash drive and you want to boot from usb to restore the pc .....There are a few things that you have to know about to do that ...
first you have to go to bios and enable boot from another device ....other than hdd /cd or flopy ... for some elder bios this isnt even a choice ..or ..if it is ,,it will be as a sub options into the hdd...choice ..
another thing that you have to keep in mind ..is that you have to disable the other options to force it boot from this one ...or ....to press f8 on boot and manually choose the usm or the stick name that will appear on boot devices...
the most important thing is that if you already formatted the hdd it does notr have a usb driver loaded and that why willl not see the device ...also the device you are using to boot ...has to be specially formatted to be bootable ....this is made ussualy with a hp format tool ...and it is explained in more than one places on the net ...just look for making a boot-able stick (usb device)
in short ...make sure the sticvk is boot-able ...second the pc ha s teh capability to boot from another device ...and this is a feature that you already enabled like first boot device ...
than things will be easy ...it will ask you to press any key to boot from the usb ...and continue like an installation from the cd ...
if you cannot do it ...I recommend using a cd ..or an image that you will ***** in a virtual cd ...for those that do not have cd drive ( use daemon tool )
Posted on Dec 21, 2009
The hardware of backspace and enter
I would first of all try removing the keyboard, and re-seating the connection cable. If that doesn't cure the problem you may need to replace the keyboard altogether.
Mar 20, 2014 | Acer Aspire 4752, AS4752 Charger, Power...
I have acer aspire 5542 how can i access in bios what i need to type before windows logo f2 or f12 or something other plz help
When you first boot up the computer the screen will flash briefly the key/s to enter the BIOS.
Try F10
Jan 10, 2013 | Computers & Internet
How to update bios on acer aspire 4752?????
go to the acer web site, they'll have the bios and the instructions.
follow them precisely as this is a good way to screw up your laptop. but if you do it correctly, it's not terribly hard and has real benefits.
use the support link or download link, find either bios or your model and then the other.
I wouldn't suggest using any beta bios as they sometimes need to have bugs worked out first.
if you do decide to update the bios
Connect a USB flash drive to the USB port on your Acer. Send all of your files and folders to the flash drive for backup purposes.
Take out your flash drive and reboot your machine. Continue to press "F2" on your computer until your BIOS screen comes up. Check the version of BIOS that your laptop contains, write it down and then reboot your machine.
Go to the Web page for Acer support (see Resources). Click on "Drivers and Downloads" and then "Netbooks."
Click "Aspire One" and click the link for the type of Aspire One computer you own. You can locate this data in the documentation that comes with your Acer.
Click "BIOS." Find the latest BIOS version from the download list.
Click on your "Download" link. Right-click this item and then select the "Extract Here" option. When it finishes the extraction process, double-click on your "WinPhlash" file.
Click your mouse on "Browse." Go to your BIOS upgrade folder and click on the file that ends in .wph. Click your mouse on the "Open" option.
Click on "Flash BIOS." Reboot your machine and then push "F2" repeatedly to start your BIOS.
Push the "F9" key and then "Enter." Reboot your Acer to finish the process
be very careful any mishap can totally screw up your computer and make it unuseable
hope this helps
Aug 22, 2012 | Acer Computers & Internet
I want to boot from DVD for Notebook Acer extensa 4230
Before Windows boots, determine which keyboard command you need to type to enter the "setup" or BIOS. Hit that key and it should get you into the BIOS. Once in the BIOS, go to the boot priority settings and set the DVD to boot first. Normally the harddrive is first.
Nov 12, 2010 | Acer Aspire 5720-4230 Notebook
Insert battery hang not working
have you tried using an extra battery? or remove and put back in the battery? if it still wont work, try updating your BIOS, check your website if they have one available.
Apr 03, 2010 | Acer Aspire 5050-3242 Notebook
Acer aspire 5738 finger print sensor problem
Hi, i have a acer aspire 5738 laptop. i do not know how to start its fingerprint option... plz help me in this... regardes in advance
Sep 01, 2009 | Acer Computers & Internet
Cd/dvd-rom drive E: not detected
plz check in the bios the cd rom is enable, then check the datacables try with a new data cable
Jun 19, 2009 | Acer Aspire 5315-2153 Notebook
Keys doesnt work
ok..... firstly check to make sure the "NUM LOCK" is off!!! if no joy get a usb keyboard and restart the pc with keyboard plugged in, hopefully if the usb controllers are enabled in the bios you will be able use the usb keyboard and enter your password, use it until you resolve the issue
Nov 14, 2008 | Acer Aspire 4520-5582 Notebook
Acer Aspire 5101after booting its freez
reboot it to an ealyear day when your usb worked
Jan 15, 2008 | Intel D865GBF Motherboard
Acer Aspire One  PC Notebook Logo
2,257 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
