Typically the fault codes are listed on the back of the unit on the "spec sheet" or they are on the tech sheet that's located under the front of the unit. Look under the lower front of the unit for a plastic document holder that's glued to the upper side of the refer "floor". It's hard to find usually, you have to pull the lower grill off and lay down with a flashlight to see the technical sheet holder. Some models have the paper folded and stuck to the grill in little holders too.
Another choice is to Google for error codes or fault codes. Note that Samsung is also Maytag so they cross reference easily.
Sorry I don't have all the tech sheets available to me, I leave them at the customers for other techs to use. I guess I should start a database of photocopies so I can have them for questions like this.
