I have a Model 2015WCS wine cooler. The thermostat control and sensor is part number 2767-1. You can find it from a number of suppliers. I called U-Line to get these instructions. They worked! I cannot stress how important it is to work carefully and slowly so you do not kink or crimp the new sensor or damage any of the refrigeration lines.
UNPLUG THE UNIT! Remove the knob and plastic front panel, and remove the back panel. Do this is a place with lots of room. Remove all of the shelves. Slightly loosen the two screws in the bottom center of the evaporator plate, inside and at the back of the storage unit. These screws secure the coiled sensing portion of the temperature sensor. Remove the screws and standoffs at the bottom of the Evaporator Plate and gently slide out the sensor. Working between the back of the unit and the back of the inside compartment, feed the coiled portion out through the hole.
Next come the HARD part. The control is mounted with two screws onto a housing within the unit. However, its removal is blocked by the mounting bracket for the button switch for the light. This button switch bracket is either riveted or spot welded onto the base of the unit. The U-Line guy told me to drill out the rivets to make room for removing the control. It's tough metal, but very possible! You will need some screws or a good pop rivet tool to re-mount the bracket when you are done. I ended up making fairly large holes and used 1/4 x 20 flat head screws.
Lay the unit on its side so you can work on the bottom side. You may wish to remove the door before doing this, or be sure the hinge in on the floor so the door will lay open. Locate where the rivets or spot welds are on the bottom outside, and drill them out to release the bracket. Take care not to drill the button switch.
After the bracket is out of the way, remove the two screws holding the Control, and feed the sensor through the back of the unit while pulling on the control. Note the path it takes for reinstalling the new one.
Now you are ready for the new part. CAREFULLY extend the sensor to its full length by gently uncoiling it. Feed it through the ho;le on the side of the housing that holds the control and then to the back of the unit. DO NOT MOUNT THE CONTROL YET. Feed the coiled end through the hole in the back of the unit. Reach inside and direct the sensor coil back into its bracket and tighten the screws. Replace the Evaporator Plate mounting screws and standoffs.
Now you are ready to mount the control in place. Using at least two screws and lock washers, secure the button switch bracket back in its original position.
Stand the unit back up and replace the back. Plug it in to verify that it is working. Replace the plastic front panel, knob, and shelves. Enjoy some wine!
