Mainboard: DUNTKE034WE
Send your email address to me, and get back a copy of the diagram by return mail.
here's my email add: [email protected] tnx a lot sir..
can u send me too??? thanks... [email protected]
me also sir
MY email add [email protected]
[email protected] also sir.i need schematic diagram of sharp Primo tv model 20V-W70M?
[email protected]
Thank you in advance!
SOURCE: philips tv model 21 pt 5007/69 circuit manuel
my tv control panel is locked.there is only on screen av1.it is not changed.
SOURCE: MY SHARP PRIMO TV MODEL 20V L75M IS ASKING FOR A SECRET NUMBER
It may be a parental lock, so u need the code or u have to reset it, check the manual on how to reset it
SOURCE: value resistor 719 of chasis serial :
I looked at the same chassis I have and the resistor has color bands green blue silver gold wich is a .56 ohm 5% 1/2 watt resistor
SOURCE: my sharp tv model 20V-J100M,,when i turn on green
ba coil around picture tube called as "yoke" is problem sum in ur tv... when copper coils become rusty or cut such problem will come in sharp tv's...
SOURCE: My sharp tv model 20V
If your SMPS IC is getting damaged all the time , you can easily source an universal SMPS unit with the required + B voltages to power your TV and this will be more reliable and will not fail as the circuit is much stable.
The failure of the STR is due to poor feedback, poor components int this section or the SM oscillations, or a faulty SM transformer.
Can I have a copy too? I do also have same model needs to be fixed please?!
