Need belt routing sequence or what im not sure how to help , if you have the belt on the right way there should be a diag on the waterpump shroud , other than that if that is gone ck local auto parts store you have to take a 3/8s drive ratchet to pull back the tensioner to load the belt i usually load the belt on all pulleys except the idler pully then i preload the tensioner and slide the belt under that pulley last , im thnking you have a 3.1 or 3.4 litre engine
need belt routing sequence or what im not sure how to help , if you have the belt on the right way there should be a diag on the waterpump shroud , other than that if that is gone ck local auto parts store you have to take a 3/8s drive ratchet to pull back the tensioner to load the belt i usually load the belt on all pulleys except the idler pully then i preload the tensioner and slide the belt under that pulley last , im thnking you have a 3.1 or 3.4 litre engine
