No spark 1998 dodge stratus 2.5 six cyl.
SOURCE: 94 Jeep Cherokee won't start
I believe the green wire is a pulse from the distributor and its a ground signal. I could be wrong since is been a while since i left the jeep dealer...I would take the coil out (2 bolts on most) and take it to autozone. They can test it in minutes for free. Either that or the ignition module but more common is coil.
SOURCE: No Start. OBDii Code P2305.
i have the same problem could someone please help ? its getting cold outside and i live 30 miles from my job.
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
SOURCE: 1995 ford f-150 4.9l striaght six
Im guessing your after the firing order?If so here it is have a good day DB
Notes
