SOURCE: plugged in, reset button is lit, won't go off
The problem is the thermostat (NC 150 C). A replacement is available at Digikey.com, item R2015025 (part no. 317-1468-ND) It's a simple replacement with the bottom removed.
SOURCE: Home touch 300 no steam coming out
If you are using tap water - there may be minerals clogging the machine. try dumping all the water out and rinsing the machine then add distilled water. That was the issue I had...
