Hi guys, my desknote is an asus degatto. i just observed that some of the letters in my keyboard are not registering. i initially suspected that it might have been caused by accumulated dust under the board. i tried to clean the boards underneath and it didn't fixed the problem. i do not know wherelse to locate the problem. i am losing time and temper on this so i might also seek your help where i can buy a keyboard for this type of unit. your response will certainly be treated as heaven sent. thanks in advance. rollie
Try to take the keyboard out and check for the connection and reconnect very firmly and hook it back again. If it si still show same issue, take off gently the non working key off the board and view the plastic pad under it for any damage or misalign and push the key back gently to be sue it is snap firmly into the base ann use your finger to test that key again for functionning. If th eissue came from the key only, you need to replace the key only. You don't have to get a whole keyboard. If all suggestion above failed, You defintely need a new keyboard.
Take the keyboard out of the laptop. now look for a model number and search it on ebay.
