Cars & Trucks Logo
Posted on Dec 18, 2008
Oil change i need to know what type filter and oil i need. i also need to know about getting a tune up
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 18, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1821
Points
12
First you need to know what size the engine is in canada its metric , how many litre? in the u.s. its cubic inches. is the engine a 4cyl. , 6cyl. or 8cyl. most tune ups nowadays consist of sparkplugs and sparkplug wires , and like the other you need to know the size of the engine. its better to go to a oil change garage when they have a special deal on.
2 Related Answers
Anonymous
  • 1066 Answers
  • Posted on Apr 12, 2009
SOURCE: oil change
all these questions can be answered at your local auto parts store.
Anonymous
  • 14 Answers
  • Posted on Aug 26, 2009
SOURCE: need to know type of oil filter wrench for a corolla 2009
fl 110
1helpful
What parts do I change to tune up my 2008 dodge caliber
For a standard tune-up, the parts needed include an air filter, oil filter, fuel filter, spark plugs, and spark plug wires. You should also have oil, transmission fluid, coolant, windshield washer fluid, and brake fluid available. A tune-up consists of topping off or replacing fluids, changing spark plugs and spark plug wires, changing the fuel, oil, and air filters, and checking the pressures of the tires. More detailed tune-ups run a diagnostic test on the vehicle to check for any codes that indicate additional issues.
What parts do you change when you get a tune up?
What do I need to do a complet tune up and oil change
What type of vehicle?
Usually this consists of Spark plugs, Wires, Distributor cap and rotor (iff equipped). PCV Valve, Air Filter, Throttle Body Cleaning, and of course oil and filter.
How much for a tune up on a cadillac srx
not cheap if its a caddy. Tune up as in, Plugs? Or do you need a full routine maintenance check. Oil change, air filter, ****** oil filter, ect. Looking at Couple hundred dollars..
When do i need my first tune up
That depends on your driving. Spark plugs can claim 100,000 miles before a change. But if you drive a lot in town stop and go, you will be putting more hours of running time than you would if it was 100k highway. I have run across a lot of vehicles that state 100,000 on ignition. The plugs may be manufactured with a hard substance such as platinum but the caps, rotors and wire are not and a tune up was needed around 75,000 miles.
The first tune up is no more different than any other. The oil on the other hand, if you did not know what was used from the factory then maybe 3000 and if you use full synthetic then go to around 5000 afterwards. Replace the fuel filter if not every oil change every other. I like doing them that often as they are cheap enough and a clean filter never hurts. It use to be said to change an oil filter every other oil change in the owners manuals. I always did the filter every change.
Transmission filter, again, depends on your driving type. Just don't negelect it or else its going to cost more than a filter and fluid later on.
2answers
What parts do i need to do a tune up for a jaguar s type
I wouldnt advise any messing around with this type of vehicle other than oil and filters change and the check the plug gaps.brake pads ect
2answers
My cavalier needs a fuel filter and oil change where do i et good service?
find a "mom and pop" type of garage. keep away from any type of chain store (midas, mieneke, goodyear, firestone, tire kingdom, jiffy tune, all tune and lube, ect) or quicky type of oil change place.
2answers
I want to tune-up, myself , where do I get information? Advice?
right here! for a tune up all you got to do is change your oil, spark plugs, plug wires, air filter. not very hard to do! to change oil, you got to drain all the oil out with a socket or wrench. make sure its not the transmission you drain. but drain oil, then take filter off, take new filter rub oil around the top on the rubber sealing. put on car. put about 5 quarts of oil in. get spark plug socket, change plugs. when you change plug wires, make sure to do it ONE AT A TIME!!! or else you will wire it up wrong and have tons and tons of problems. then air filter is pretty easy, take it out and clean it,,put back in and there you go, tuned up!
I want todo a tune up myself
for a normal tune up, the only thing you can change are, fuel filter, oil filter and oil, cabin filters, transmission oil filter and trans oil, and spark plugs. The other (tune items) such as spark plug wires and points, and timing settings are either eliminated or non adjustable. If you have the equipment you can do a computer check, but if the truck is running well it probably won't tell you much.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Oldsmobile Expert? Answer questions, earn points and help others
