Display module doing nothing. Replaced it and drain pump. Same result
SOURCE: Fisher and Paykel GWL11 will not drain...
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
SOURCE: Model: GWL11 While using the washer, a strong
You can order parts online from SearsDirect.com
SOURCE: Wont power on after replacing drain pump.
could be just the fuse, but failing that check all circuit boards for signs of blowing or burns, some machines when there is a short on the pump blow the circuit on the timer which is the most expensive part to replace best of luck
SOURCE: washer will not drain
90% chance that is the pump is pumping water at all, there is blockage between the tub and the drain pump. If there is no water coming out of the drain line. either extremely clogged(odd) or pump motor is bad, and windings are not allowing rotation.
SOURCE: GWL11 fisher & paykel washer draining very slowly
Hi just read your posting.Now when you say it 'catches', what exactly does this mean?Was the pump corroded in any way?After the pump drains for awhile is it hot to touch?Best guess on the fault is pump.But I have seen on a machine, the motor controller being faulty.Is your pump the model with an external fan?Have you or can you borrow an electrical test meter to test the OHMS of the pump windings?Please reply with additional information on the questions and I am sure I can help you further.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the washer is not powering up, then it is possible that the motherboard is faulty. Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
