When camera is turned on, the lcd screen is fuzzy and grey. no menu or images appear on the screen.
SOURCE: Camera image does not show up on LCD
This model has had problems with the CCD element that acts as the eye of the camera. I would recommend that you return the camera to Canon in New Jersey and let them replace it at no charge to you. Good luck to you. Joe Weibel customelectronics.org
SOURCE: Blank LCD screen
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
SOURCE: IXUS 500 LCD screen has gone black.
This sounds like it might be a defective CCD imager, and is a known defect for your particular model camera.. If so, Canon should fix this for you for free if you live in the US, Canada, and a select few other countries. If you live outside the US, contact Canon support for your country to see if they'll still honor the advisory (some still will, especially if you stress you knowledge that this is a known defect of the camera). They may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please see this link for more info.
Affected cameras with this problem include:
A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
SOURCE: Blank screen on Canon Powershot S2is camera
hi.if you are telling both viewfinder and lcd are blank or black the problem is in the shutter that you found inside of the lens are not open.sometimes the cuase of the is humidity or moist goin inside of the shutter thats why it will not work properly or stuck up.if you can open your camera and adjust the shuuter from lens unit its better .but if not its better you bring to service center and request for adjustment.
by the way try also to reset your camera to default setting maybe it will help you.
thank you
Testimonial: "Thank you so much for taking the time to help me, i will try your suggestions tonight, really appreciate your help, thanks again"
