Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
yes replace both ,batterry and the charger,thath way youl be shure and the new battery must be charge for 12 hrs ...
and should works fine after ..
hope that will help you
regards Alan..
The S210 is a camera, not a battery charger. In order to charge the battery, remove it from the camera and insert it into the supplied battery charger.
Hi amber_penn, battery charging problems usually come from two sources, the battery or the battery charger.
Check the contacts on both the battery and the charger for oxidation, dirt, etc. Try cleaning the contacts with a little alcohol on a swab. The charger seemed to still work judging from the humming sound. Next step would be to buy a new battery.
Try to follow this link http://www.livingroom.org.au/photolog/reviews/miscellaneous/norcent_dc420.php
Plug came off the wall?
What do you mean by this, the plug to what exactly the charger?
How is the charger camera battery set up?
Where is the red light on the charger?
More detail please
