Question about Craftsman Garden
18.5 hp 42 inch cut, craftsman riding mower loses power after 10 min.
I have been working on this mower for about a month, have had many helpful replys, but; problem still there. It runs great for 10 min then starts losing power, almost quits, then comes back up again in power, after a few minutes the same thing happens again, over and over again. Finally will quit. I have cleaned the air filter, put in a new plug set at .30, removed the coil (armature-magneto) cleaned it, and reset at 13 thousands- a business card length away from the fly wheel, changed oil and filter, removed carb and flushed with carb cleaner, renewed gas lines and filter, removed gas tank- flushed and cleaned, cleaned gas cap and checked the gap in the top it is open and clean. when it quit I checked the plug to see if I was still getting sparks I was and plenty. I know the problem is either in the firing or the fuel, but; I am running out of ideas... need more help folks. Don. crimson9
  • 7 more comments
  • Don Carroll Aug 09, 2012
    I meant the thickness of a business card tight against the fly wheel and coil. Not length.
  • stevenschulz Aug 10, 2012
    I too am having the same problem. My B/S will run for about 5 minutes then cut out. I have tried to clean the carburator, I checked the fuel pump, which is pumping fine, and also checked the anti backfire silanoid which seems to be functioning. Im not sure what step to take next?
  • Don Carroll Aug 10, 2012
    I am working on the choke right now on mine. with it running I can move the choke by hand and it settles out. But, don't really have a lot of knowledge on chokes.
    gas line filter is in correctly.
  • Don Carroll Aug 11, 2012
    please read what I have already done before replying. Thanks.
    I need help in freeing up the choke, it is not moving freely, and I have no knowledge on how to fIx the choke, anyone can help me there?????
  • Don Carroll Aug 12, 2012
    I figured it out, took the choke apart and replaced the spring, runs fine.
    problems fixed. thank everyone for the many ideas you gave me to track it down.
  • Dennis Key
    Dennis Key Aug 14, 2012
    Glad you found it.
  • Craftsman Master
  • 2,478 Answers
Us start here, remove fuel line from carb. Hope fuel runs out.
Check the direction of fuel filter. There arrows on it. Arrow toward
carb.
Posted on Aug 10, 2012
  • 1 more comment
    fuel filter is in correctly
    fuel filter was o.k. , but thanks for the input anyway, I found problem and repaired it, the problem was a broke sprink in the choke.
  • Don Carroll Aug 14, 2012
    thank you Dennis, you are the only one, so far; who actually read my who script, and problem details. That is professionalism. If I can ever help you, I am here. I don't know how they rate people, really don't care, but; I am 70 years old and have some knowledge, a little bit, about everthing, and am willing to share.
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 33 Answers
SOURCE: Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Posted on Jul 04, 2009
Robert J Gordon
  • 11 Answers
SOURCE: I have a Craftsman 42 in. 15.5 hp lawn tractor
check an see if the cabuerator is getting fuel and check make sure sparkplug is getting continous fire from the coil
Posted on Sep 13, 2010
I have craftsman 18 hp run 20 min get hot cut off change coil
Be sure fins are clean. Its around spark plug. And engine clean.
Jun 19, 2014 | Craftsman 18.5 HP 42"
Murray 42 in 17 hp doesnt start
i would look at the safety switches that being the most common cause
Jun 16, 2012 | Garden
I have 15.5 hp 42 inch cut riding mower when i turn the key all i can hear is a clicking sound
have you tried to jump start it with your car?if so check your safety switches
Apr 26, 2012 | Craftsman Garden
I have A craftsman riding mower 18 1/2 hp 42 inch deck have changed spark plugfuel filter took off tank and blowed it out but the mower still cute off after about 10 minutes like it has no gas what else...
Do you have a Briggs or kohler engine.I am having the same problem.I have changed the fuel filte, fuel pump, and cleaned the carb.Sears has been no help at all.The reason I ask about the engine you have is that people are having the same problem no matter what engine they have.So therefore it probably is not the engine so it is something else on the mower.My mower runs fine for about 10-15 then starts to stutter and backfire.I am continuing to pursue this problem and I will post back here if I come up with anything.
Jul 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
May 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Cuts out and stops sometimes after 30 min. or so
check your fuel delivery system. It sounds like a blocked filter, failing pump or a restriction in the fuel line.
Apr 25, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
415 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
