My Canon rebel xsi won't turn on. I changed the battery and still nothing. Yesterday it was fine now nothing!! HELP
Hi please try to do this and let me know. Remove the battery and give a look inside the battery compartment with spot light. Make sure that place are clean and there no damaged mark. Specially look the Battery connector pins. That should in proper place , not bend, not even sulfur layer there. Use ear buds and drop of alcohol for cleaning. After checking if every thing Ok then some how the power supply not able to connect the circuit board. Its happens when the connectivity cable disconnected or damaged, circuit board short or the power transformer stop working. For all this internal fault part confirmation you need to visit electronic repair center.
but before visit for repairing make sure the battery which one you use that's is fully charged with working condition. Thank you
SOURCE: Flash won't open on Canon Rebel XSi?
The openning flash button only works on non automatic shooting modes.
On creative zone (automatic options with predefined options) the flash will rise automatically, based on the current exposure conditions. On "Flash Off" mode won't rise the flash ever.
Let me know, please if it solve the problem
SOURCE: Busy when i use the flash.
The capacitor in the flash circuitry needs to be charged to a before
the flash can be fired. This chargeing time is termed as flash recycle
time and duriing this window the camera wilkl show that it is
'BUSY'.
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
SOURCE: My Canon EOS Rebel XT will not turn on anymore.
This same thing just happen to me. I took it to Ritz and its not the battery. Did you ever find out what was wrong with your camera?
SOURCE: Canon Rebel Xsi autofocus doesn't work
It could well be the lens, Take it off and clean the contacts on the lens and body,
