Camera in excellent condition but zoom stopped working , menu won't come up and coupe other functions not working. Camera only one year old (i lost the receipt though !)
SOURCE: Problem with F470 Fine pix camera
sounds like the keypad ribbon has either popped out of it's socket or, and this would be the common fault, the ribbon has broken. In which case fuji will be your only way to fix and get it serviced at the same time. last quote I recieved was £80.
source a donor camera on ebay for the cheaper option
SOURCE: Fujifilm E900 camera zoom does not function!
If the shutter and Zoom function both do not operate, you need to send the camera to an authorised repair center. Was the camerra exposed to salt/sea air? If so, you can take a soft rag and gently wipe around the lens area where it meets the body, remove the battery, reinstall the battery and try it. If not, send it in.
SOURCE: a210 zoom error
When you first turn the camera on, grab the lens, pull on it slightly. Turn the camera off and try it again. If it doesn"t work the first time , pull on the lens slightly again. It worked on mine
SOURCE: Camera won't focus when using optical zoom
I had same problem. Found that doing a complete reset fixed it. Go into setup and at end there is a factory reset. If not working after that would suspect your ccd sensor is on way out. They should last 5-7 yrs. Be cheaper to get another cam with way prices have come down
SOURCE: zoom, Menu/OK, up, left,right all don't work but
Try moving down, and then moving up. Similarly, try moving the opposing directions for left and right. If there is no way to go in a certain direction, on a certain screen, it will appear that the button isn't working. I think you can solve it now. I have faith in you.
