Got phone form a relative as a present, he said he bought it from someone somewhere. Recognises my SIM card but does not let me do a thing. So obviously, I'm not using said phone right now. Would you be able to send me the security code something via email? thanx
SOURCE: Unable to text
This is a common problem. But there is a solution for this problem.
go to Messaging. Then hit Options. Scroll down to settings.
Hit text message. Options - Then "Message Centres".
Hit the Edit button and the following number should come up:
+47973100973
Save it and try sending messages. If again the same problem exist then call up your customer care who provides the services of your phone like Airtel, Reliance etc.. Ask the message center number and follow the above steps and save that service center number. Hopefully it should work. Thank you......
SOURCE: incoming calls barred
Goto settings there you will see a option "Restore to factory settings" .Try it and let me know if this fix the issue.
SOURCE: cant send sms form my n95 8gb
You need to back everything up onto a memory card or onto Nokia PC Suite and do a reset by pressing *#7780#. I had exactly the same problem and that solved it.
Good luck!!
SOURCE: problem with nokia n95 8gb
Oops this doesn't sound good. Try following (hard reset) : push and hold the green button and 3 button and while holding them push power button until it restarts. If this doesn't help then back to the shop for replacement.
SOURCE: computer can't detect my N95 8GB when using DKE-2 cable & unable to send SMS using my phone. shyam.
make sure you have the correct usb cable which you looks like to correct one, check make sure there is no damage to the cable and/or the phone
if there is damage check that the cable is plugged correctly into the device, if you still have a problem contact me on msn and i will guide you through step by step
[email protected]
Michael
Universal Mobiles Coventry LTD
Mobile Phone Engineer
