We have a leak above the inlet sump. It appears to be easy to remove. I am not sure if water is backing up causing water to push back against the seal forcing water back out. Are there any suggestions? I looked up part 505 at the attached link for the GE dish washer site.. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5206718&diagram_id=29414340#d29414340 If it is as simple as replacing the part, I can do that. If not, what else might I do to troubleshoot the problem up or downstream?
SOURCE: Leaking door (Running Water)
being in the uk i dont know this appliance, but the fault is probably that it is overfilling caused by crap in the airchamber or the hose leading to the pressure stat blocked or a split in this hose
SOURCE: GE Nautilus Dishwasher Problem
check water level is ok. check its heating. open door when in operation and check if spray arms are rotating. if not, take them out, run water into centre hole and check water comes out of jets. note the spray arms only rotate with water coming out of angled jets at end
SOURCE: Leak from dishwasher
I currently had the same problem with mine and the culprit was the boot that screws on to the spray arm which serves as the seal from the spray arm to the motor.To find out spin the base of the spray arm loose and take off the screw tightened clamp that holds the boot to the motor. Mine had dry rotted and leaked very badly.The part as only about $10. Hope this helps
SOURCE: leaking dishwasher
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
