Machine smell foul.. Tried using bleach, vinegar, changed gasket and cleaned drain hose. Anything else to do or buy new washer
SOURCE: How do I make my
you should ( ifyou have, reinstalla the origianl shipping brackets) thiswill preventthe machine from bouncingaround internally
SOURCE: How do I make my WM 1832 CW washer ready to move?
It is best to re-install the four shipping bolts in the back of the machine during the move. If you don't have them, contact a dealer. Please don't rate, as anything but a Fix-Ya lowers my score. Thanks.
SOURCE: Machine will not discharge water
Any error codes? Pumps out OK?
Sounds to me as if the cold water inlet screen is plugged up, preventing rinse water from entering machine. Turn off the cold water to the machine and remove the cold water supply hose. Check the screen inside where the hose came off the machine. Run some water out the hose into the drain or a bucket before reconnecting to machine. Let me know if you still have problems.
SOURCE: Mold on gasket of LG WM2016CW
the biggest problem with front loaders is that the seal is so good you end up with a moisture issue all the time (which will cause mold). My suggestion to you is always leave the door open when not in use and also try not to leave clothes in the machine after a cycle is over. leaving the door open and a few good cleanings will solve your problem
SOURCE: can the lg washers wm
It depends on the thickness,content and weight of the comforter.
If you have to stuff it in, don't wash it in your machine..take it to a laundromat.
Or if it is down filled, take it to a dry cleaner.
If it is a cotton filled quilt it will get very heavy when wet and may damage your machine, so I would take one of those to the laundromat as well.
If it is a light weight polyester-filled comforter, twin size and fits easily in your machine with out stuffing it in, it is probably okay.
