Question about LG WM2688HWM TROMM SteamWasher
TE code wm2688hnm - LG WM2688HWM TROMM SteamWasher
    Top Expert:
  • LG Master
  • 12,223 Answers
Proceed with common sense and logically, fix it use the Vom or DVOM .God bless you
For this error code you need to check both the water heater or element and thermistor, basically the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
On non-display panel models this fault code is denoted by the lights for 95, 60, 40 and cold being lit or flashing.
  • Check water heating element
  • Check heater for contunuity,
  • Check steam heater for continuity usually
  • Check thermistor or temperature sensor
  • Check the thermistor resistance,
  • Check wiring to water heating element
  • Check connections to water heating element and temperature sensor
Posted on Aug 03, 2012
6ya staff
SOURCE:
Our lg wm2688hnm gives an error saying check water supply but it has water in it. Goes through wash and gives error on rinse cycle and stops.
This could be a controller failure because it is unable to detect the state of the water supply and subsequently stops at the rinse cycle because the water supply wasn't detected.
Aug 27, 2018 | LG Washing Machines
Error code tE
if you replaced the thermister
and tE comes up
then its the heating element has failed
and or its thermal safety fuse set up perhaps failed also
Apr 28, 2015 | Washing Machines
Lg tromm wm2688hnm schematics
yes it sounds like you have somthing in the pump this video will help
Jul 22, 2013 | Washing Machines
I have a model WM2688HNM LG Washer and have a TE code. I would like to get a repair manual to show me how to open the cabinet to get directly to the thermistor to check for a loose or broken wire.
undo the screws at the back take the lid off then pull out the dispenser draw take two screws out holding front display on then jiggle the display out might be lugs or clips holding it in place as well then take the bottom kick plate off lever it with a flat blade screw driver it just pops off then open door take door lock screws out then take spring off the door gasket then undo the screws on the top & bottom of the front panel then your in
Jan 05, 2011 | Washing Machines
TE error code on my LG WM2688 washer. Thought I started cycle, went downstairs. Checked back and noticed it never started and had a tE error code on screen. Manual says, unplug and call for service. ...
TE Error Code = Heating Error - Thermistor failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 29, 2009 | Washing Machines
MC909X Barcode types
found someone in the whs that knew what to do
Nov 19, 2008 | Zebra Symbol Technologies MC909X-G Series...
Lg dishwasher trouble codes how to clear
my LG dishwasher error code TE and won't start- can you tell me what the problem is?
Jun 30, 2008 | Dishwashers
Washing Machines Logo
375 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
