I want to wipe the hard drive of my laptop
SOURCE: acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
SOURCE: how to format acer aspire 5610 without cd
To format your laptop you need to insert a windows installation disc into the drive, restart the machine and before windows loads up you should see a "press anykey to boot from cdrom"
press key and follow the instructions, it will give you the option to format the laptop before it reinstalls it again.
any problems just let me know
All the best
John
SOURCE: aspire 5610 problems with motherboard
Very simply can be some loose hardware.
First thing is to take the battery out and unplug it from the wall. Plug it back in w/o the battery and try turning it on. If it boots great, if not unplug it to shut it off immediately and try turning it on again. Lot of no boot issues are because the system is in a failed sleep/hibernate and just wont get out of it until you do the above.
Try re-seating the RAM (hopefully it's not under the keyboard or somewhere hard to get). The RAM they ship with these units is low yield stuff so even though the RAM is good, and the slot is good, they're not making a good connection cause it's cheap stuff so you may want to try a different RAM chip all together.
Sometimes it can be a loose processor which is usually a lot harder to get to unless your savvy.
SOURCE: Acer Aspire 5610 Notebook driver download
http://www.drivers-software-download.org/tag/acer-aspire-5610-notebook-driver
http://drivers-download-driver.com/tag/acer-aspire-5610-notebook-driver
http://laptop-notebooks-drivers.com/tag/acer-aspire-5610-notebook-driver
http://driversdownloadsfree.com/tag/acer-aspire-5610-notebook-driver
http://notebooksdrivers.com/tag/acer-aspire-5610-notebook-driver
