White smoke usually indicates there is a problem with the cooling system to the engine. Here are some things I would check.
Coolant
Radiator
Thermostat
Hose from radiator to thermostat
Most importantly, the valve cover gasket. When you replace this type of gasket, we need to make sure you torque down the bolts in a certain pattern at a certain torque.
if it is a 3.8liter engine generally about and hour there is 4 10mm bolts in the front valve cover and the rear you may have it remove the spark plug wires and coilpack/ignition controll module bracket.
Yes, you need a Rocker cover (valve cover) Gasket kit. Remove the valve cover, remove all old O-rings and cover gasket, clean grooves and mating surfaces without gouging or scratching them, put the new gaskets on as per factory recommendations, tighten to the proper torque and you're done. The spark plug holes in the cover are part of the valve cover gasket kit. Any Napa, Car Quest, Pep Boys, Auto Zone will have it.
First take the plastic cover and carefully loss out the bolts and take every one of them and replace the new gasket and place the bolts back , it is as easy 1234
when u replace the head gaskets u must also replace any parts gasket that u remove (valve covers, intake manifold etc.) to get the heads off, they sell what is called a "Valve Grind" gasket set that is what u need, it will have all the gaskets in it u need..
Its easy. I did mine about a month ago. You need to take off all the bolts on the top part of the motor. there are some tubes on the left side of the motor by pushing them out of the way... you take the old one off and replace it with the new one making sure its aligned and the you put it back on.. the bolts need to be hand tightened kinda as tight as you would do your tires.
Its kinda hidden at the back.. you can take off the upper intake plenum to gain a bit more access.. some people also take off the washer arm housing.. theres a few bolts under the cover that mount it to the firewall
Are you sure the Valve Cover and not just the Valve cover gasket??
Any ways go to Auto Zone and pick up the Valve cover gasket, RTV Silicone selant, Gasket Scraper, and a can of Brake parts cleaner spray.
Disconnect the battery cable from the negative battery terminal, Remove the items which are in your way: Pull the spark plug wires off the spark plugs and remove them from their brackets, remove the PCV hoses, and remove the throttle cable from its brackets and position it out of the way. Loosen the fasteners in this order, I believe there are 11 bolts holding the Valve cover down. Remove one bolt and count to the next 5th bolt and remove it and count to the next 5th bolt and remove it, do this till all the bolts have been removed on a circular pattern. Carefully remove the valve cover from the engine head. If your just going to replace the Valve cover gasket, Remove the gasket from the valve cover. Thoroughly clean the mating surfaces of the valve cover and the engine head. Use a gasket scraper to remove all traces of old gasket, and then use the Brake parts cleaner to clean any remaining oil from the surfaces. If you bought a new Valve cover, Apply RTV silicone sealant to the gasket and engine head around the cutout areas of the valve cover. Note you still have to clean the heads on the engine. Lay the new gasket in the groove in the valve cover. Reinstall the valve cover with its new gasket on the engine head. Tighten the bolts in the same order you removed it in. Do Not Over Tighten the Bolts that hold the Valve Cover down, you'll crush the new gasket and will get an oil leak. Note: If the valve cover does not come off the engine head easily, use a block of wood and a hammer to bump it in an attempt to jar it loose. If absolutely necessary, you may slip a flexible putty knife between the head and the cover to break the seal. If you purchased a valve cover gasket kit, don't forget to replace the small rectangular gasket and the spark plug seals as well while you have the valve cover off the car. You may buy some Brake cleaner to clean off all the oil which has leaked all over the engine. DO NOT attempt to pry the cover off the head using a screwdriver or chisel. Be very careful not to introduce foreign matter into the engine. If you get anything (dirt, metal shavings, bits of old gasket) into the engine. DO NOT over-tighten the valve cover fasteners. On the engine, the fasteners need only 17 to 34 in-lbs of torque. Your A/C system has a leak in it. all system has a slow leak and common, You can get a re-charge kit at Auto Zone to save some money, but if your A/C needs charging again in 2 weeks or less then there is a larger leak due to a bad seal and is cheaper to have a A/C shop locate the leak and replace the seal that has gone bad. Good luck and hope this help. keep me posted, be glad to help.
The first step is to remove all the parts that are in the way of you being able to remove the valve covers. (Ex.: air intake, loose wires etc.) Then you will need to remove your valve covers (using basic tools) and be very careful to not let anything get on your lifters, which your valve covers protect. Once you have the valve covers off compare the new gaskets to make sure they are the right size. Then remove the old gasket and replace with the new one using a high temp gasket sealant (available at any auto parts store) to attach the gasket to the valve covers. Then tighten down snug and check for leaks after replaced.
