If your tank is in a
room equipped with air conditioning, that would be your best bet; however if
not, there are a few other options available to you.
I found a great do it yourself article on making a homemade
aquarium chiller - take a look and see if it helps.
http://saltaquarium.about.com/od/diychillerplans/ss/sbsdiychiller.htm
If this does not help, then try the following ideas:
Fill a plastic bottle with water, freeze it, and
then place in the tank
Adjust your lighting
• Attach small clip-on fans to the hood of your aquarium and aim them towards the waters surface
Aquarium chillers can cost anywhere from $100-$1,500
depending on the quality of the chiller itself.
Here is a link that will lead you towards a good selection of chillers
at various prices.
If you're not using any lights or pumps in your aquarium I advise
you to get an aquarium fan it will definitely do. If you do use thing such as
lights and water pump that warm up your tank you should definitely get a
chiller, try the Oceanic Aquarium Chillers.
The best brand of
aquarium chillers is USA Prime Aquarium Chiller and you can find
their products at http://www.aquaticeco.com which
also offers other aquarium chillers brands.
You'll need a chiller
when the ambient room temperature is higher than the desired temperature of
your aquarium. This can happen due to many reasons such as:
1) If you live in a warm
part of the world and decreasing the room temperature is not good enough.
2) If you wish to keep
cold water species in your aquarium.
3) If you have installed
heat emitting equipment that increases the water temperature such as light,
pumps etc.
I highly recommend you to get a USA Prime Aquarium Chiller you
wouldn't be disappointed. You can also get chillers from Aqua Logic Aquarium Chillers, Deltec Eco Cooler Aquarium Chiller, Coolworks
- IceProbe Aquarium Chiller, Oceanic Aquarium Chiller, TECO SeaChill Chillers
and Tunze Aquarium Chiller the all solid chillers companies.
An in-line water chiller
is equipped with internal cooling coils. Water is pumped out of the aquarium,
into the chiller where it is cooled, and then back to the aquarium again. An
in-line chiller can be placed away from the aquarium and is therefore easier to
hide.
