Kenmore Master
- Posted on Dec 14, 2008
Re: kenmore 8114p643 showing f1.
F1 is either a bad electronic control board or a bad touch pad.
You find the solution on :kenmore oven with "F1" error
I quote:
"You have either a bad ERC (clock) or a bad touch pad.
- Disconnect power to stove
- Gain access to the back of the clock (electronic range control or ERC).
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on.
- Turn power back on to stove.
- Watch for the F1 and listen for the beep.
- If you get the F1 and beep, replace the ERC.
- If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
If you can't find a new ERC you can send yours to stove clock repair and get it repaired!"
