I have a Roper washing machine that just started making noise on spin cycle. Washer still works fine. Its just the noise. Model # RAX4232JQ0. Any suggestions???
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin,
the main suspect is the drum bearings. Drum bearing failure is common on
washing machines due to water getting into them if the drum bearing
seal fails. To check for drum bearing failure you can take the belt off
and spin the drum by hand. If the drum rumbles when spun then the
bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in
the drum which can be checked for by lifting the drum up and down from
the drum lip behind the door seal. A further symptom of drum bearing
failure is a brown rust patch underneath the washing machine and down
the back of the outer drum, underneath the drum pulley (where the belt
goes) There are usually two small holes at the back of the drum bearings
where water that has got past the drum bearing seal trickles out, and
it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions
inside the water pump. This will cause noise when the washing machine
is emptying the water. Coins or other obstructions can get trapped
between the outer tub and the inner drum. This would produce a lot of
noise on spin as they coins get tossed around inside. Usually, spinning
the drum by hand will not reproduce the noise in the case of coins as
the coins drop to the bottom of the tub when the washing machine isn't
spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This
can also be checked for by taking the belt off and running the motor
alone.
A knocking noise can be a loose tub weight. This would be worse with
heavy loads and would not be present on spin with no washing in. This is
because the knocking noise is caused when the tub (or outer drum)
shakes about on spin. Without washing inside the drum the tub doesn't
move. Another symptom of a loose tub weight is grey concrete dust under
the washing machine.
It's very tempting to ignore noises while the washing machine is still
otherwise working. Some noises can be ignored as they will not develop
into serious faults. Other noises, if left, will cause extensive damage
and can end up costing considerably more than if tackled early or these
days writing the washing machine off. Of course the problem is that you
can't tell which of the categories a noise falls into - so ignore them
at your own risk.
SOURCE: Loud noise when spinning
I agree with Gittos on the bearing assessment. This considered part of the drive system. If it's less than 5 years old, your next move is to contact Sears and claim a warranty repair on the tranny (it has a 5 year warranty on it). If it's more than 5? Well, honestly it wouldn't be worth the repair. You'd have spent more money on all the parts required than what the unit is worth (worth= what it would sell for in working condition on the market). Hope it's less than 5!
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
