Replaced the battery, did the reset for the battery, need to know how to reset time and date.
SOURCE: armitron m516 no setup instruction
Armitron has a website with instructions for some watches.
SOURCE: WATCHES
i hope this helps....
the top right says st/stp....tells you the year
the bottom right is the light...
the top left is the reset....
and the bottom left is mode...alarm, stop watch,and time 2
SOURCE: Armitron Watches
I have a Men's Amitron LCD Chrome Watch which I lost the instructions for setting the
time for the hour and minutes. The date is correct, but we just went off daylight savings
time and I am now an hour ahead of everyone who could turn their watch's hour back.
It has four buttons one on top left and on bottom left
one on top right and on bottom right
I can't seem to find the right combo to change the hour back by one hour??
SOURCE: can't set time on a 2 button armitron watch
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Armitron says if the model is not listed on their site call them 718-784-0700. I did and they promptly e-mailed me PDF.file instructions for my M516 watch. - David
SOURCE: How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
