SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
SOURCE: Bosch Exxcel 1200 Express Washing
I had the same problem- machiine not spinning and a few days later not turning at all. Display would go from 11min to 1min.
I did 2 things - 1) changed the brushes on the motor- cost £7.50 .
2) whilst working under the machine disconnected pipe from drum to pump and emptied it- found 2 coins in the bellows.
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
SOURCE: error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
