Tip & How-To about Archery
A few simple tips you can use for shooting your bow and to improve your arrow grouping . first it starts out with a good stance your feet should be shoulders with apart but not over spread apart.you will want to face 90 degrees to either the left or the right of the target depending on your shooting hand .second your draw ,when you draw your bow the bowstring should sit right below the far outside corner of your eye..thirdly calming your self take a few deep breaths and hold your last breath till your ready to shoot and settle your pins (sights) on your target remember to use the right pin for the right distance.. fourthly remember not to drop the bow when you release the arrow.i dont mean actually dropping the bow on the ground but lowering your extended arm holding the bow forward to quickly before the arrow has time to release .dropping the bow can and will cause your arrows to drop too ...shooting your bow at longer distance will tighten up your arrow grouping at closer distances
Recurve bow arrows can travel up to 150 mph. compound bow arrow can travel up to 200 mph and in longbow arrows the velocity is slower because the weight of the arrows.
An arrow
consists of a shaft with an arrowhead at the tip of the shaft. Arrow sizes vary
from one another ranging from 18 inches to 5 feet, the flight velocity of
arrows generally ranges from 100 to 300 km/h, depending on the bow power, and
the condition of weather and wind.
