KitchenAid Blender KSB560OB 5-Speed Onyx BLACK Kitchen Aid Refurbished KSB560-OB Polycarbonate Logo
Cathy Daniel Posted on Jul 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to open Kitchenaid KSB560OB to replace motor
How to open the casing to replace the motor
Ross Keen
Level 3:
  • KitchenAid Master 1,365 Answers
  • Posted on Dec 22, 2013
Ross Keen
KitchenAid Master
Level 3:
Answers
1365
Questions
0
Helped
582762
Points
2445
Undo the 4 screws at the bottom. Before you do that though remove the clutch/motor drive. You cannot take the motor out with that still fitted.
1helpful
My kitchenaid blender won't work. Lights for all the settings come on but motor won't start
I expect you will find that the motor is open circuit. There is a thermal fuse incorporated into one of the field windings which can be replaced with a bit of messing about. A job for a retired appliance service person if you want to keep the price down. Did one today, took about an hour from start to finish.
1helpful
The blender will not turn on, the lights for each selection blink on and off but the blender will not spin.
Remove the bottom cover 1nd unplug the motor from the PCB, check the motor for a circuit with your multi meter. If the circuit is open then remove the motor and locate the thermal fuse attached to one of the field windings under the metal tie and tape for insulation. Test the fuse for a circuit, if it is open then you have 3 options, replace the whole motor, replace the thermal fuse only (it will need to be aftermarket as KA only supply motors complete) or just bypass the faulty fuse.
My blender motor doesn't work. I don't know what happened. Just tried it one day and it didn't work. Any suggestions?
Remove the bottom cover (unplug the power first) and check the motor for continuity. If it is open circuit check the thermal fuse which will be taped over against one of the field windings close to a brush holder. You can either replace or bypass the fuse if that is the case. Kitchen Aid will only be recommending full motor replacement but it most often it's not really necessary.
Why is the unit not turning on?
Check the motor for continuity, it may be open circuit. If it is locate the thermal fuse covered with insulation tape on one of the field windings (where the metal clip is) Check that for continuity, if faulty bypass or replace it.
Problem with soup mate,all lights flashing but nothing happening
If this is a Kitchen Aid blender with the flashing lights then you will need to remove the motor base cover and check the motor for a circuit. If it is open circuit then either replace the motor or locate the thermal fuse (under some white tape and aluminium clip on one of the field windings) and either replace or bypass fuse if it is open circuit.
The control went crazy
Motor is probably open circuit, that is the main cause of the flashing lights. New motor OR replace the thermal fuse on one of the field windings if you are up to the task.
Blinking lights blender
Probably open circuit motor. Locate and replace thermal fuse on motor windings or replace the motor. After you have proven the fault of course. Check with a meter.
KitchenAid KSB560TG0 Blinking lights
How do you replace a bad circuit in Kitchenaid blender KSB50B4
It is more likely the motor is faulty than the circuit board. Test the motor with a meter.
Kitchenaid Blender Classic
Same thing happened to me. Opened it up and along the red wire to the motor is a bass fuse. Went to the hardware store and then I replaced it. Works fine.
Top KitchenAid Blenders Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
