Voicemail is not set on the phone. its a setting you give to you phone number. You can check with your network or service provider the numbers used to activate or deactivate your voicemail. it may look like *100# depending on your network
<p>He the volume of the iPod Touch can be affected in some way,
the definition of musical sound check the volume limit set in the settings
device preferences. The tool of sound check, which can also be found on iTunes,
check your iTouch music and video library for the stabilization of the
equalizer song for a constant level, the volume limit reduces the volume to
grow beyond a set point, which helps the potential adverse effects of hearing
loss caused by loud music. <br />
<p><br />
<p>1. Press the button to the left of the iPod Touch. The
volume switch top left of the iPod Touch increases the sound volume, and gives
a volume icon on the screen as it grows. Accident on the volume button for the
iTouch, it seemed sound problems. Touch the "Music" icon to start
playing the song, press the volume for music to grow. <br />
<p><br />
<p>2. Adjust the volume control settings. Tap Settings on the
iPod screen Touch, Touch "Music" and tap "volume limit."
Slide the tab to the right of way to reduce the volume bar to change the limit
of the maximum. Press the Home button to save and Settings. <br />
<p><br />
<p>3. Sound Check off. Tap "Music" in the Settings
window and slide the guide Sound Check to the left to the sound check feature
off. A Sound check song keeps playing very hard at the same level. While the
function prevents sudden jumps in volume, can also lead to a series of songs to
play very soft, depending on the quality of the music. <br />
<p><br />
<p>4. Adjust the volume to your headphones. Press the
"+" button on your Apple headphones, the volume of a music or video
playback to increase. If a song or video does not play, the volume control
adjusts the volume on the iTouch. <br />
FN or function key and the icon key that looks like a mouse or touch pad. That combination will activate and also deactivate this mouse or touch pad feature.
Should be a icon on your keyboard that shows a mouse or touch pad icon - Just use your FN (Function key) and that icon to activate and to deactivate the pointer or touch pad.
Hope this information helps ya.
Nerd Tech-Junkie Will
1. Play the song.
2. Tap the now playing screen.
3. On the Now Playing screen, you will now see play and volume controls at the bottom of the screen. At the top is track information. Under the album title is a scrubbing bar that indicates the time remaining in the song.
4. A small icon that looks like two circular arrows is on the left side below the scrubbing bar. Tap this icon once to repeat the album. The icon will turn blue when repeat is activated.
5. Tap the icon again to repeat the current song. The icon will change to show the number 1 inside a blue circle.
6. Touch the icon a third time to cancel any repeat. The icon will turn white when it's deactivated.
1. Play the song. 2. On the Now Playing screen, you will see play and volume controls at the bottom of the screen. At the top is track information. Under the album title is a scrubbing bar that indicates the time remaining in the song. 3. A small icon that looks like two circular arrows is on the left side below the scrubbing bar. Tap this icon once to repeat the album. The icon will turn blue when repeat is activated. 4. Tap the icon again to repeat the current song. The icon will change to show the number 1 inside a blue circle. 5. Touch the icon a third time to cancel any repeat. The icon will turn white when it's deactivated.
Could you please check the music bitrate you downloaded to your PSP? It should have at least 128 or 192 as its bitrate value to get a decent sound.
Also do not set your PSP volume too high as it may hurt your hearing (when using headphone) or it may hurt your PSP system speaker (when not using headphone).
I recommend you to always enable the AVLS (Automatic Volume Limitation System). You can always choose to activate/deactivate AVLS from the System Settings menu.
