Dishwasher will not start. Only see "E01" on display when powered.
Do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE
& HOLD program buttons, then turn unit on by pressing ON/OFF button.
When program buttons are released, lights above them will flash. To end
test program, press ON/OFF button.To check program indicator
lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and
hold each program button. When REGULAR WASH program button is pressed,
CLEAN light also comes on.
To start testing, press both POWER
SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has
ended and a fault was detected, the following indicator lights will be
lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To
check for heater, high limit or flow switch problems, start testing
until heating starts. Using a meter with a current coil, measure current
going into dishwasher. If current is ~ 11 A, then heater, high limit
and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high
limit or flow switch are faulty.
If water level switch (f1) has
failed (opened), REGULAR WASH light will come on and unit will
continually fill and drain where testing won't be completed. If flow
switch (e5) has failed (opened), water won't heat (to 150?F) and water
won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE
& HOLD light will come on immediately and testing will end shortly
after water has started circulating.
If more than one fault occurs, more than one light will be lit.
My dishwasher does not have the buttons you described. From left to right, I have On/Off, then Half Load, then a left arrow (next to Power Scrub indicator light, the first of six indicator lights ending with Rinse & Hold), then a right arrow, then a Delay button, then Start button. The specific model number is SHE6AP02UC/05.
use the instr. manual or download from www.retrevo.com or www.fitness.manualsonline.com and procedd according with the instr.manual and common sense. God bless you
SOURCE: I have a Bosch SHU5316UC
P stands for program in computer algorthms. The device displays program whenver chages were made to the default settings. A powered on devices least has malfunction only requires reseting to attaon default features. Depending on the type of device, reset would be a button that is pressed held for an extensive duration to clear the entire corrupted data to make way for default. Refer to the device user guide also for further asssistance.
