Where can I pick up a instruction manual for my camera
SOURCE: Putting film into nikon f60
It is fairly simple. Insert the film canister with the hole side (not the projection) down. Insert the spool of the camera into this hole and slide the canister inside the chamber. Now pull the film out slightly so that the leader (the narrow portion at the end of the film) aligns with the orange mark at the lower right end of the film chamber. Make sure there is no slack in the film. Close the door and turn on the camera.
SOURCE: Don't know how to open door latch on nikon 35mm SLR camera
You haven't stated which model you have, but generally most SLR's open by pulling upwards on the film rewind crank (the knob on the left side of the top-plate as viewed from behind). If this doesn't work then add the exact model as a comment to my answer and I'll try to give you specific instructions for your model.
SOURCE: I have a Nikon N90s /film 35mm slr. I haven't
If the switches and contacts are dirty that would do it. If that happens the cost of service may exced the cost of buying a used one.
SOURCE: I need to download a manual for my Nikon N65 SLR
Go to nikon.com/manuals and select what u desire
J.
