If water keeps freezing in the line you need to replace the water valve after you get it melted out again / valve is letting a little water seep into the line and freeze up / larry
Replace the water valve. Shut off the water going to the ref, take off the back panel so you can see where the water goes to the water valve. This valve is usually held on by two screws and has two wires which can be unpluged. If you have water in the door then you will have a double valve and four wires.
This valve is not closing all the way and allows water to drip into your icemaker which will freeze and stop up the water line. Be sure to get this ice out of the water line inside the freezer. A hair dryer works.
