SOURCE: FRIGIDAIRE FRONT LOAD LTF2940ES3
The first thing to check would be you incoming hoses. Pull the machine out, UNPLUG THE WASHER throw down a couple of old towels or have a bucket handy. Unscrew the hoses from the back of your machine and check the little filters to make sure they are clean. If they are, replace them and make sure the water faucets are turned on fully.
While you are there, check your drain hose to make sure there is not a big clog that is stopping the machine from doing anything.
If you can not see a problem there go to the www.frigidaire.com site /support or customer service/enter your washers model # when prompted and you will get al ist of manuals and tech data on your washer. You can download anything that you think might help you. It is all in acrobat format, so if you dont have acrobat reader, you will need to go to www.adobe.com/acrobat and download and install it for free. Good luck to you.
