Marina Slim Power Filters: S20 - up to 20 gallons A287 - Aquarium Power Logo
Posted on Jul 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i install it to my tank? - Marina Slim Power Filters: S20 - up to 20 gallons A287 - Aquarium Power
Fahr Quad
Level 3:
  • Master 776 Answers
  • Posted on Dec 24, 2019
 Fahr Quad
Master
Level 3:
Answers
776
Questions
0
Helped
310471
Points
2299
What is "It"? If you mean how do you install the filter, hang it over the back of the tank, install the suction tube on the right side, install the filter elements, and fill up the filter with tank water using a clean cup. Put the top on and plug it in. It should gurgle a bit until the excess air is purged and should run quietly after that.
https://kensfish.com/products/marina-s20-slim-power-filter
What are the steps to replace the fuel pump on a chevy trailblazer 2002
This is what it looks like and it is located in the gas tank:
First, you'll need to use up as much fuel as possibly, if not, you'll have to drain the tank. Next:
  1. Drain the fuel tank.
  2. Support the fuel tank.
    1. Remove or disconnect the following:
    2. Negative battery cable
    • Filler neck from the tank
    • Shield from tank and tank straps
    • Fuel lines and vapor hose from pump
    • Electrical connection from fuel pump
    • Fuel tank
    • Fuel pump/sending unit assembly by turning the locking ring (located on top of the fuel tank) counterclockwise using a spanner wrench
    • Fuel pump from the fuel lever sending device
  • NOTE
    The fuel pump strainer must be in a horizontal position when the fuel sender is installed in the tank. When installing the sender assembly, make sure that the fuel pump strainer does not block full travel of the float arm.
    To install:
    1. Install or connect the following:
      • Fuel pump in tank with new seal around opening
      NOTE
      • Tank and connect fuel lines and vapor hose
      • Tank to the frame. Torque the fasteners to 33 ft. lbs. (45 Nm).
      • Shield
      • Fuel filler neck and clamp
      • Negative battery cable
    2. Refill the tank.
    3. Run the engine and check for leaks.
    // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 33; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]>
    tip
    Duplicate Cartridge Error - Which one is causing it
    The purpose of this exercise is to rule out ink tanks that are behaving and isolate the one(s) responsible for the duplicate. Please perform the following:
    1. Open the printer and remove all ink tanks.
    2. Insert a single ink tank in the printer then close the cover.
    3. Confirm whether the printer recognizes the installed tank properly. If it does, it will indicate it does not detect the other ink tanks, as they are not currently installed in the printer.
    4. Repeat steps 1-3 with another ink tank.
    5. If the printer at any time indicates two of the same ink tanks are installed, the cause will be the last tank installed. For example, if you inserted an ink tank earlier, and you later inserted another ink tank, and it said two of the same inks were installed, the cause of the issue is the last ink tank.
    Hope this helps
    Mike
    1helpful
    What is the codes means po452 and po453
    The codes indicate a problem with the fuel tank pressure sensor. One code is for no volts, the other is for high volts. Without a scanner hooked up to monitor. I have to go with you have a bad fuel tank pressure sensor. this is an emissions control sensor. the tank is pressurized and the sensor monitors it for leaks etc. the tank must come out as it is mounted on top of fuel pump module
    REMOVAL PROCEDURE
    1. Raise the vehicle.
    2. Remove the fuel tank. Refer to Fuel Tank .
    3. Remove the fuel tank vapor pressure sensor electrical connector.
    4. Remove the fuel tank pressure sensor.
    INSTALLATION PROCEDURE
    1. Install the fuel tank vapor pressure sensor.
    2. Install the fuel tank vapor pressure sensor electrical connector.
    3. Install the fuel tank. Refer to Fuel Tank .
    4. Lower the vehicle.
    Thanks.
    3helpful
    ERR0R U071 MORE THAN 1 INK TANK OF THE FOLLOWING COLOUR IS INSTALLED. (CANNON PIXMA MP500)
    Hi there
    For troubleshooting purposes,
    Perform the following:
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Replaced the magenta cartrage. arror check Ink
    The Error "Check INK U140"
    Causes : Possible causes are as follows :
    * The ink tank may not be installed properly (The lamp on the ink tank is off).
    Install the appropriate ink tank.
    * The ink tank not be compatible with this machine. (The lamp on the ink tank is off).
    Install the appropriate Ink tank.
    The machine will not print of the wrong type of ink tank is used or if it is installed incorrectly.
    Be sure to install the ink tanks in the proper order. The proper arrangement from the left to right is Black - (CLI-8BK), Black -(PGI-5BK), Yellow - (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
    Replacing Tanks
    1) Ensure that the machine is on.
    2) Raise the Scanning Unit (Printer Cover) until it stops.
    The Paper Output tray will open automatically and the Print Holder moves to the center.
    Impoprtant : If the Scanning Unit (PRinter Cover) is left open for more than 10 minutes, The Print Head Holder moves to the right. Close and reopen the Scanning Unit(Printer Cover) to return the Print Head Holder to the center.
    3) OPen the Inner Cover.
    4) Press the Open button to open the Paper Output tray if it does not open automatically and remove the ink tank whoe lamp is flashing red fast. Do not touch the Print Head Lock Lvever. Remove only the ink tank.
    Important : * Handle the ink tanks carefully to avoid staining clothing or the surrounding area.
    * Discard empty ink tanks according to the locakl laws and regulations regarding disposal of consumables.
    Note : Be sure to replace ink tanks one by one when replacing more than one ink tank.
    5) Prepare a replacement tank.
    a) Remove the new tank ink from its packaging, then pull the orange tape so that the protective film does not remain on air hole. Then remove the film.
    b) Remove the orange protective cap from the bottom of the ink tank and discard it.
    6) Install the ink .
    a) Install the ink tank into the Print Head.
    b) Press on the Push button on the ink tank until the ink tank snaps firmly into place.
    c) Ensure that the ink tank clicks into place and then its lamp lights red.
    Important : Make sure to install all the ink tanks to enable printing. The machine cannot be used unless all the ink tanks are installed.
    7) Close the Inner Cover.
    Note: Ensure that the Inner Cover is closed, Printing will not occur if the Inner Cover is open.
    Hope this help. PLease rate my response.
    Thanks
    have a good day.
    Color tank isn't installed --- but it is!
    Make sure that all tickers are off from the tank and clean the housing good and run self clean first and reset the printer
    HOW TO TAKE A FUEL PUMP OUT A 2001 ISUZU TROOPER
    REMOVAL PROCEDURE
    1. Disconnect the negative battery cable.
    2. Drain all the fuel from the tank.
    3. Install and tighten the drain plug. Tighten Tighten the drain plug to 20 N.m (14 lb ft.) .
    4. Remove the fuel tank.
    5. Remove the retaining screws from the fuel tank.
    6. Remove the fuel pump assembly from the fuel tank.
      1. Cover the fuel pump opening in order to prevent dust, dirt, or debris from entering the fuel tank.
      1. Install the fuel pump assembly. Tighten Tighten the fuel pump assembly mounting bolts to 3 N.m (27 lb ft.) .
      2. Install the fuel pump assembly retaining screws.
      3. Install the fuel tank assembly.
      4. Fill the tank with fuel.
      5. Tighten the fuel filler cap.
        1. Connect the negative battery cable.
        REMOVAL PROCEDURE # 2
        REMOVAL
        CAUTION: When repair to the fuel system has been completed, start engine and check the fuel system for loose connection or leakage. For the fuel system diagnosis, see Computers and Control Systems/System Diagnosis.
        1. Disconnect battery ground cable.
        2. Loosen fuel filler cap.
        3. Drain fuel. Tighten drain plug to the specified torque after draining fuel. Torque: 20 N.m (14 lb ft) - M8
        4. Remove fuel tank assembly (1).
        5. Remove fuel pump (FP) assembly (2) fixing screws and remove the FP assembly.
        NOTE: After removing FP, cover fuel tank to prevent any dust entering.
        INSTALLATION
        1. Install FP assembly (2).
        2. Install fuel tank assembly (1).
        3. Fill the tank with fuel and tighten fuel filler cap.
        4. Connect battery ground cable.
    3helpful
    2answers
    1999 jeep cherokee do you have to remove the fuel pump to replace
    The combination Fuel Filter/Fuel Pressure Regulator is located on the fuel pump module. The fuel pump module is located on top of fuel tank.
    The filter/regulator may be removed without removing fuel pump module although fuel tank must be removed.
    REMOVAL
    1. Remove fuel tank. Refer to Fuel Tank Removal/Installation.
    2. Clean area around filter/regulator.
    3. Disconnect fuel line at filter/regulator. Refer to Quick-Connect Fittings for procedures.
    4. Remove retainer clamp from top of filter/regulator. Clamp snaps to tabs on pump module. Discard old clamp.
    5. Pry filter/regulator from top of pump module with 2 screwdrivers. Unit is snapped into module
    6. Discard gasket below filter/regulator.
      1. Before discarding filter/regulator assembly, inspect assembly to verify that O-rings are intact. If the smallest of the two O-rings can not be found on bottom of filter/regulator, it may be necessary to remove it from the fuel inlet passage in fuel pump module.
      INSTALLATION
      1. Clean recessed area in pump module where filter/regulator is to be installed.
      2. Obtain new filter/regulator (two new O-rings should already be installed)
      3. Apply a small amount of clean engine oil to O-rings. Do not install O-rings separately into fuel pump module. They will be damaged when installing filter/regulator.
      4. Install new gasket to top of fuel pump module.
      5. Press new filter/regulator into top of pump module until it snaps into position (a positive click must be heard or felt).
      6. The arrow molded into top of fuel pump module should be pointed towards front of vehicle (12 O'clock position).
      7. Rotate filter/regulator until fuel supply tube (fitting) is pointed towards front of vehicle (12 O'clock position).
      8. Install new retainer clamp (clamp snaps over top of filter/regulator and locks to flanges on pump module).
      9. Connect fuel line at filter/regulator. Refer to Quick-Connect Fittings for procedures.
      10. Install fuel tank. Refer to Fuel Tank Removal/Installation.
    WARNING: THE FUEL SYSTEM IS UNDER CONSTANT FUEL PRESSURE EVEN WITH THE ENGINE OFF. THIS PRESSURE MUST BE RELEASED BEFORE SERVICING FUEL TANK .
    Two different procedures may be used to drain fuel tank (lowering tank or using DRB scan tool).
    The quickest draining procedure involves lowering the fuel tank.
    As an alternative procedure, the electric fuel pump may be activated allowing tank to be drained at fuel rail connection. Refer to DRB scan tool for fuel pump activation procedures. Before disconnecting fuel line at fuel rail, release fuel pressure. Refer to the Fuel System Pressure Release Procedure for procedures. Attach end of special test hose tool number 6541, 6539, 6631 or 6923 at fuel rail disconnection (tool number will depend on model and/or engine application). Position opposite end of this hose tool to an approved gasoline draining station. Activate fuel pump and drain tank until empty.
    If electric fuel pump is not operating, tank must be lowered for fuel draining. Refer to following procedures.
    FUEL TANK REMOVAL
    1. Disconnect negative battery cable at battery.
    2. Release fuel system pressure. Refer to the Fuel System Pressure Release.
    3. Raise and support vehicle.
    4. If Equipped: Remove fuel tank skid plate.
    5. Remove 4 fuel hose shield mounting bolts and remove fuel hose shield from body.
      1. Remove fuel tank fill hose and vent hose clamps at fuel tank filler tube. Remove both hoses at fuel filler tube.
      2. Remove exhaust tailpipe heat shield mounting bolts and remove shield. CAUTION: To protect fuel tank from exhaust heat, this shield must reinstalled after tank installation.
      3. Place a hydraulic jack to bottom of fuel tank. WARNING: PLACE A SHOP TOWEL AROUND FUEL LINES TO CATCH ANY EXCESS FUEL .
        1. Disconnect fuel supply line from fuel extension line near front of fuel tank. Refer to Fuel Tubes/Lines/Hoses and Clamps. Also refer to Quick-Connect Fittings for procedures.
        2. Disconnect EVAP canister vent line near front of tank.
        3. Disconnect fuel pump module electrical connector (pigtail harness) near front of tank. Harness connector is clipped to body.
          1. Remove two fuel tank strap nuts. Position both tank support straps away from tank.
          2. Carefully lower right side of tank while feeding both fuel hoses through access hole in body. Fuel Tank Full And Not Drained Using DRB Scan Tool: To prevent fuel loss through hoses, keep left side of tank higher than right side while lowering. Do not allow hose openings to drop lower than top of tank.
          3. Continue lowering tank until clear of vehicle. Place tank on floor with left side (hose side) higher than right side
            1. Drain tank by removing fuel fill hose at tank. Fuel fill hose is largest of 2 hoses. Insert the drain hose (from an approved gasoline draining station) into hose opening. Drain tank until empty.
            2. If fuel pump module removal is necessary, refer to Fuel Pump Module Removal/installation for procedures.
            INSTALLATION
            1. If fuel pump module is being installed, refer to Fuel Pump Module Removal/installation for procedures.
            2. Install fuel fill/vent hoses to tank fittings. To prevent hose from kinking, rotate each hose until index mark on hose is aligned to index tang on fuel tank.
            3. Install hose clamps to hoses. Position clamps between index marks on each hose.
            4. Position fuel tank to hydraulic jack.
            5. Raise tank into position while guiding fuel fill and vent hoses into and through access hole in body.
            6. Continue raising tank until positioned to body.
            7. Attach two fuel tank mounting straps and mounting nuts. Tighten nuts to 10 Nm (90 in. lbs.) torque. Do not over tighten nuts.
            8. Install both fuel hoses to fuel fill tube. Tighten both retaining clamps.
            9. Position fuel hose shield to body. Install and tighten 4 mounting bolts.
            10. Connect fuel pump module pigtail harness electrical connector near front of tank.
            11. Connect fuel pump module supply line near front of tank. Refer to Quick-Connect Fittings for procedures.
            12. Connect EVAP hose near front of tank.
            13. Install exhaust tailpipe heat shield.
            1. Install fuel tank skid plate (if equipped).
            1. Lower vehicle and connect battery cable to battery.
    PIXMA IP1500 - CANON PRINTER
    Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head.
    1. Check that the printer is powered on and open the front cover.
    2. Wait until the print head moves to the center.
    3. Check if the ink tanks are installed properly.
      Ink tanks installed correctly
      Ink tanks installed incorrectly
    4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
      Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
    5. Close the front cover.
    WILL NOT PRINT!!!
    Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. (See the illustration below this paragraph for ink tanks recommended for this model.) If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. sj402022.jpg
    Ink Tanks:
    - BCI-24 Color
    - BCI-24 Black
    1. Make sure the power is turned on.
    2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
    3. Open the Paper Output Tray (2).
    4. Open the Inner Cover.
    5. Check if the ink tanks are installed properly.
    6. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    7. Close the Inner Cover.
      CAUTION: Press the center of the Inner Cover until the cover locks into place.
    8. Return the Scan Unit to its original position. The LCD displays a message asking if you replaced an ink tank.
    9. Press [+] to select [NO] and exit.
    Top Marina Fish Experts
    Keith
    Level 1 Expert
    ADMIN Andrew
    ADMIN Andrew
    Are you a Marina Fish Expert? Answer questions, earn points and help others
